The fact of the matter is that boundaries for chapters are a necessity. People in general need boundaries. Using proper edicate, minding your manners, are typical boundaries for us to use on a daily basis. The lines however are not necessarily cut and dried. They move around a little or are crossed back and forth to varying degrees yet not to extremes.
We need to look at this exercise, boundary reorganization, much like an artist working with watercolors. Unlike oils or acrylics, watercolor has a personality of it's own. Characteristics that are not to be controlled by the artist. They will settle in areas that you may not expect and at levels that you don't always know. But the resulting color, texture, shape etc becomes a pleasant surprise adding to the finished artwork. If you overwork it however, you get 'mud.' That's what politicians do with laws. They overwork them, make hard and fast rules, then they end up with mud and no one is happy. With the chapter boundaries we need to set parameters/boundaries but with the flexibility to allow the finished product to serve each individual member for their best interest. Let the members mix, overlap, change the landscape, without 'running off of the paper.' This way the end result will be like a beautiful painting that can change on it's own when the business or industry environment changes and never be outdated.
I think that having boundaries for chapters is necessary but they should be easy to cross over when circumstances warrant it. PPFA mission statement says 'PPFA will...provide forums contributing to...a sense of community.' Making it easy for members to mingle, associate, and work with other members of their choosing would be one way to fulfill that mission. You can't have a hub or even a chapter for that matter without leadership so if there are hubs they will naturally form by the members who take on leadership of the chapter. I don't think we need to or should make a rule for hubs but rather just let them happen as leadership takes shape and allow members to gravitate to the area that best serves their needs and desires. Let's stick to the mission.
